Hi I am looking to upgrade to a larger format press and I will primarily be running 24pt stock. We presently run a Ryobi 524gx and overall have been happy with it so I would consider a Ryobi again. I know people generally recommend a Heidelberg CD but I was hoping to get input on other brands as well. Price will be a factor and that is why a Heidelberg may be out of my range. I would be needing the larger format B2 size that can print up around 23" long.
Local service would generally play a big factor but in my area there is no longer dedicated Heidelberg techs so service will not be super easy regardless of which press I go with. In the past few years I know a few KBA presses have come into town so perhaps they may have service techs coming through. I know Heidelberg operators are more plentiful so would pretty much need to train someone from scratch for anything else. I hear the Man Rolands can be tough to learn...how about KBA?
Most of my runs will be between 1,000 - 10,000 sheets. In most cases paper grain will be correct (23" x 29" sheet) but when I do run wrong grain it will be a smaller sheet most likely (19" x 25").
I am also pretty much a 1 shift shop so not huge volumes and therefore don't want to break the bank.
As for vintage I am hoping to get something maybe 2008 or newer...unless there are recommendations for certain years to stay away from.
Any thoughts on the above mentioned presses?
