Having an interesting discussion the other day with a friend regarding hi fidelity printing and the ability to transfer and hold micro dots from plate - blanket - substrate and what is the current limiting factors that make this process difficult for some to achieve.
His thoughts were that even if the plate can hold the micro dot, the chemistry used on the press will effectively wash the micro dot off the plate and not allow it to transfer to blanket and then substrate.
Anyone out there currently transferring to substrate micro dots that could make text characters invisible to the naked eye, but visible under microscope without issues of dot loss or failing to transfer?
What are your thoughts on the current limiting factors?
