I need to know
how can I apply - (Add) five color (spot color ) to layer in photoshop file
Wouldn't trapping be applied as in any other scenerio, at the RIP?
If you built a trap into a PS file which was later scaled the trap would be incorrect.
In this case, probably no - trapping engines (at least all the ones I've used) don't "look" within an image to trap inside of the image. They look at where an image touches other objects to determine if traps are required.
You do bring up a good point about the trap being scaled - it would be important to make sure this image is at correct size to begin with. I usually make a 1-pixel trap, but you may require larger depending on your needs. Can't do smaller than 1 pixel.
In most cases, since you are printing digitally, trap is not as much of an issue as it would be on a conventional press.
