How Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical Equipment
Andy Qui
How Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical Equipment - Vizlent Label M...png
Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical equipment by using facestock and adhesive systems that self-extinguish rather than spread flame, and by being tested and certified so they do not become a fire path on the equipment they identify. UL 94 rates how a material reacts to an open flame, while IEC 62368-1 is the safety standard that audio, video, and information technology equipment must meet. A compliant label is engineered so it supports, rather than undermines, the equipment's overall fire-safety case.
Understanding how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products starts with a clear distinction. UL 94 is a flammability rating for the label material itself, and IEC 62368-1 governs the finished equipment and the materials used inside it. A label that carries the right flammability rating helps the equipment maker keep the whole product inside its certification.
Specifying compliant labels for an electronics build? See how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products on Vizlent's flame retardant label range before you commit to a bulk order.
What UL 94 Actually Measures​
UL 94 is a plastics flammability standard from Underwriters Laboratories that evaluates how a material reacts to an open flame. It measures ignition time, whether the material self-extinguishes, and whether flaming drips ignite a cotton indicator below the sample. These same principles decide how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical use, since the label material is tested the same way as any other plastic.
The ratings run from HB, a horizontal slow-burn test, up through the vertical V and 5V series that apply progressively stricter criteria. The difference between V-0 and V-1, for example, is how quickly burning must stop and whether igniting drips are allowed. This is central to how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical enclosures, where a higher rating is often required near live parts.
UL 94 RatingTest OrientationWhat It Means
HBHorizontalSlow burning on a horizontal specimen
V-2VerticalStops burning within 30s; flaming drips allowed
V-1VerticalStops burning within 30s; no igniting drips
V-0VerticalStops burning within 10s; no igniting drips
5VB / 5VAVertical (larger flame)Most stringent; 5VA allows no burn-through
For a fuller technical breakdown of the burn tests, the UL 94 classification guide from Protolabs is a useful external reference. A key point it makes is that a UL 94 rating is thickness dependent, so a material that passes at 1.5mm may fail at 0.8mm, which matters for thin label constructions.
Where IEC 62368-1 Fits In​
IEC 62368-1 is the modern safety standard for audio, video, information, and communication technology equipment, replacing older standards for this class of product. Rather than prescribing fixed constructions, it uses a hazard-based approach that looks at energy sources and how they could cause harm, including fire. This is the other half of how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products, since flame-retardant labels are one of the many material choices that feed into meeting this standard.
Within that framework, a label on or inside an enclosure is treated as part of the fire enclosure's material set, so its flammability matters. This is precisely how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical safety, by carrying a material flammability rating that the equipment maker can point to during certification. The label does not certify the equipment on its own, but the wrong label can compromise an otherwise compliant design.
Flame-retardant labels support IEC 62368-1 compliance, and here is how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products in practice, when they:
  • Carry a documented UL 94 flammability rating for the construction
  • Are tested at the thickness actually used on the product
  • Hold print legibility for safety and rating markings over the product life
Need rated stock matched to your enclosure material? Vizlent's engineering team aligns constructions from our self adhesive material range to your UL and IEC requirements. Request samples and documentation to verify on your build.
Flame-Retardant Versus Flame-Resistant​
The terms sound interchangeable but describe different behaviors, and the distinction matters for specification. Flame retardant materials are engineered to slow ignition and self-extinguish once the flame source is removed, which is the category UL 94 covers. Flame resistant materials, by contrast, resist ignition more inherently and are tested under different standards such as those used for textiles and protective equipment.
In label terminology this causes real confusion, since buyers search for flame retardant labels, flame resistant labels, a flame retardant tag, flame retardant stickers, flame resistant tags, and even simply flame labels while meaning the same electrical-equipment product. For electrical enclosures and components, the correct category is almost always flame retardant, self-extinguishing material rated to UL 94, which is how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical designs in practice. Getting the terminology right prevents ordering a textile-grade product for an electronics job.
Common terms buyers use for the same rated product include:
  • Flame retardant labels, flame resistant labels, and flame labels
  • A flame retardant tag, flame retardant stickers, and flame resistant tags
  • Compliance markings, rating plates, and enclosure identification labels
Applications Across Electrical Equipment​
Rated labels appear anywhere a fire-safety case has to hold, from enclosures to internal components. Flame-retardant labels for electrical equipment maintenance carry service data, ratings, and warnings that must stay legible and safe for the life of the unit. Seeing how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical service needs, the same constructions cover flame-retardant labels for electrical equipment and equipment identification on switchgear, drives, and control panels.
The breadth of use is wide, spanning flame-retardant labels for electrical equipment and supplies in industrial settings, flame-retardant labels for electrical equipment and parts at the component level, and flame-retardant labels for electrical equipment and appliances in consumer and white-goods products. Across all of these, how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products stays the same principle. Buyers evaluating flame-retardant labels for electrical equipment companies should confirm each supplier can document the UL 94 rating for the exact construction and thickness they intend to use.
Typical application points include:
  • Electrical enclosures, switch housings, and control panels
  • Internal components, cable guides, and connector housings
  • Appliances and white goods needing rated identification
  • Service and maintenance labels that must survive the product life
A Note on Furniture, Upholstery, and Sourcing​
Not every flame-related label is an electrical product, and mixing the categories causes sourcing errors. Fire retardant labels for furniture and fire retardant labels upholstery serve textile and furnishing regulations, which are governed by different standards than UL 94. If your product is electrical equipment, these furnishing labels are not the right specification, even though search results often blur the two.
For electrical work, focus on how flame-retardant labels and packaging, formats, and volumes fit your build. Understanding what flame-retardant labels are at the material level is the same understanding of how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical products, and then sourcing flame-retardant labels bulk for production while following flame-retardant labels best practices for testing and documentation protects both compliance and cost. A dependable flame-retardant labels business relationship rests on documented ratings and free samples, not on price alone.
Before ordering rated labels, confirm the supplier can provide:
  • The UL 94 rating for the exact construction and thickness
  • Documentation you can cite during IEC 62368-1 certification
  • Flexible formats and bulk volumes for production runs
  • Free samples to validate print and performance on your line
Building rated identification into appliances or industrial gear? See how compliant labels fit these products on Vizlent's appliances and industrial solutions page, then reach out to start a sample trial.
Frequently Asked Questions​
Do flame-retardant labels make my equipment UL or IEC compliant on their own?​
No, a label alone does not certify equipment. UL 94 rates the flammability of the label material, while IEC 62368-1 governs the finished product and all its materials. A rated label supports compliance by not adding a fire path, and by providing documentation the equipment maker can cite. The overall certification depends on the whole design, not any single component.
What UL 94 rating do electrical equipment labels usually need?​
It depends on the application and where the label sits relative to live parts, but vertical ratings such as V-0 or V-1 are common near electrical hazards. HB, a horizontal slow-burn rating, may suffice in lower-risk locations. The equipment maker's safety assessment determines the required rating. Always confirm the label's rating at the thickness you will actually use.
What is the difference between UL 94 and IEC 62368-1?​
UL 94 is a material flammability standard that classifies how a plastic reacts to flame, from HB up to 5VA. IEC 62368-1 is a product safety standard for audio, video, and IT equipment that uses a hazard-based approach covering many risks, including fire. UL 94 ratings feed into the material evidence used for IEC 62368-1. They work together rather than being interchangeable.
Is flame-retardant the same as flame-resistant for labels?​
No, they describe different behaviors. Flame-retardant materials slow ignition and self-extinguish once the flame is removed, which is what UL 94 measures and what electrical labels need. Flame-resistant materials resist ignition more inherently and are tested under textile and protective-equipment standards. For electrical equipment, specify flame-retardant, UL 94-rated labels.
Why does label thickness affect the UL 94 rating?​
UL 94 ratings are thickness dependent, so a material that passes at one thickness can fail at a thinner gauge. This matters for labels because they are thin by nature, and the rating must be validated at the actual construction thickness. Never assume a material carries a rating across all thicknesses. Ask for documentation covering the exact gauge you will use.
Can the same label be used on furniture and electrical equipment?​
Generally no, because furniture and upholstery labels follow textile and furnishing regulations, while electrical labels follow UL 94 and support IEC 62368-1. The test standards and material requirements are different. Using a furnishing-grade label on electrical equipment can create a compliance gap. Match the label to the standard that governs your specific product.
What documentation should a flame-retardant label supplier provide?​
A supplier should provide the UL 94 rating for the specific construction, ideally with reference to the relevant certification, and confirm the tested thickness. They should also supply technical data you can cite during your own equipment certification. Free samples let you validate print durability and performance. Documentation and traceability matter more than a headline price.
How do I choose a flame-retardant label supplier?​
Choose a supplier that can document flammability ratings against a named standard and confirm them at your required thickness. In-house coating capability, technical data, and free samples are strong signals of reliability. Confirm they offer the formats and volumes your production needs. Verified, documented performance matters far more than the lowest quote in a safety-critical application.
Ready to specify compliant labels? Define your enclosure material, required rating, and thickness, then request free samples and documentation. Knowing how Flame-Retardant Labels Meet UL 94 and IEC 62368 for Electrical equipment is the difference between a clean certification and a costly redesign.
