How to achieve better inkjet output quality for pics?
Stickman42
I'm running the insides of perfect bound books on continuous Oce/Canon inkjet printers and Xerox Nuveras. Black print only. Most of the time, our clients supply files ready to print. Other than that we'll scan previously printed books. See the two attached pictures. The tops of each are an example of what we get from our inkjet printer, the bottom half is the same file printed on the Nuvera (laser). We'd like to run just about everything on our inkjet printer. I understand that inkjet ink is a liquid that gets absorbed into the paper, while toner stays on the surface, yielding different results. I also am aware of the affect of paper selection on quality when running inkjet. Our clients will not go for the cost of high end treated paper. We use 50/60# Husky instead.
What I'm asking is for ideas on what steps or settings should be applied to this type of photo to be printed to help out the inkjet quality. Having to test print each photo and adjust brightness/contrast is something we have done, but it really hampers the workflow.
digidave
The best answer would be to reach out to your local Canon Solutions Advisor or Regional Color Specialist and see if they can come in to take a look at your printer and workflow. If you don't know who they are, send me a PM with your company name and location and I can send you their contact info.
Otherwise, it could be a matter of relinearizing the paper if it hasn't been done in a while. It could also be a combination of the types or colorspace of the incoming images and the color management settings within the workflow.
Koenig & Bauer Video
Canon 2022
The Video You Really
Need To Watch
View The Video
