HP Scitex 700 Ink Replacement
Hello All,
My wide format guy left and I am now learning the quirks of our HP Scitex 700. I am curious if the machine will prompt me to replace the ink or if I should replace the ink when it is low? I have 2 inks on 0%-1%. There is still a decent amount of ink in the box though. Will it hurt the machine if I wait longer to replace them?
The instruction manual says this:
The amount of ink in the ink supply box is tracked by the printer software and recorded on its
corresponding profiler. The control panel displays a bar graph with the ink levels in each ink box.
When the control panel shows that the ink is low, replace the ink box with a full ink box of the same
color, and replace the profiler.
