Hydraulic Cutter advice- Baum/Polar or Challenge?
Brett S
We are currently looking at a small hydraulic cutter for our print shop, and wanted some opinions. First our shop equipment and cutting needs. We run both small offset presses (AB Dick QP25 and 9985) and digital eqipment (Xerox Versant 180 and Ricoh 8100). The majority of our sheets are 8.5x11, 12x18 and 13x19. We do have to cut some folio sheets so the 25"+ cutter is a good fit. Any cutter we choose will be a great replacement and upgrade for our current MBM electric cutter.
We cut everything from 20# bond to 16-20 pt cover. Business cards, postcards, trilfold brochures, saddle-sttich booklets (face trim) etc. Our shop has one shift, and the cutter will not run more than 4-5 hours any day and most days will run 2-3 hours.
The hope is to find a nice hydraulic cutter that runs on single phase electric, but willing to install three phase if the best piece of equipment requires that setup.
Our focus has been on the Polar 66 (looking at both the 66 Eco and 66 Plus), the Baumcut 26.4 and the Challenge titan 265TC. We are central to Pittsburgh, Cleveland and Buffalo so all equipment and service would come from outside the area.
Please let me know your thoughts and if there are any cutter suggestions beyond the above list. Thanks in advance.
SoggyWinter
My experience is limited to one Challenge machine, but I would not buy another piece of their equipment based on service attitude from them alone. Perfecta and Polar have good reputations. I have a local hydraulic repair company service my machine since the dealer tech is an expensive plane ride away.
Seeking Knowledge
Hello Brett,
I have worked with Bruce, the owner at Colter and Peterson and he was good to us. It is one of the biggest cutters the Saber X15 Plus, it is a monster. It was a bit bumpy initially but they lived up to their word. They also sell reconditioned, smaller ones, here is a link to their reconditioned machines. They are in New Jersey, so not too far.
Best of luck!
SK
Brett S
A good place to check on used cutters, Maple Heights, Ohio
Yes, Boggs/Wired bids is always a great starting point. My issue buying a used cutter and finding someone to service it. Apprecite it thanks
Brett S
Hello Brett,
Best of luck!
SK
will check them out thanks.
kdw75
We have Challenge cutters and have used them since the 70s. I can't say enough good things about the older ones. They are simple and very reliable. Of course the more stuff you get, the more there is to go wrong and if you aren't doing high volume work, do you really need a powered back gauge?
printing656
I liked the Challenge Titan 200 but not their larger 27/30"+ units. At these sizes I prefer a Baum/Polar unit. In my opinion, I'm not a fan of the larger Challenges because the unit I tested ran a hydraulic pump the whole time, whether you were cutting or not. The Baum only runs the pump when it's making a cut. Who needs all that noise when you're not cutting?! Their direct service has been pretty good, very expensive parts though.
Puch
We had a Mohr (Polar) 80 NET for five years. Apart from the knife and oil change, it needed zero servicing. A wonderful machine, indeed.
kdw75
Very true, but our 70s 26.5" Challenge is still running on the original hydraulic pump. :)
InSoft
Learn more..
