iGen3 - offline perfect binding glues
graphixcreator
Has anyone found a good perfect binding glue that adheres well to covers printed 2 sides on an Xerox iGen3? Oil residue from fuser hinders adhesion.
Any suggested glues that work would be appreciated.
Does the fuser oil get applied to the whole sheet or just the imaged areas ???
If it's just the imaged areas a decent sized glue trap should do the trick...
Otherwise i think you may be out of luck as even normal offset inks cause issues with glue... maybe ask xerox they seem to have a lot of custom solutions for digital... considering it's their machine they should have a solution ?
Any printing on the inside of the cover will expose the spine area to fuser oil, which tends to repel conventional EVA adhesive.
There are some labor-intensive work-arounds (one customer we know used a sanding wheel to abrade the spine area), but the best fix is to print one-side only or use a PUR adhesive.
The July issue of American Printer magazine has a good story on PUR (see Polyurethane reactive (PUR) adhesive success | Important considerations).
Commercial disclaimer: I work for Standard Finishing Systems which offers a range of Horizon PUR binders (see Multiple Clamp Perfect Binding from Standard - Standard Duplicating Machines Corporation).
PUR alternative for digtital print binding
those having issues releted to fuser oil shuld add smartplasma from packsmartinc.com
works like magic, much better and cheaper option than PUR.
We have been using CB Bourg for over one year, all glue reltated issues are gone
YouTube - Smart Plasma by Pack-Smart
