Illustrator paths
Macmann
Path appears smooth with rounded radius in preview mode but that contour is not visible in outline mode. How do I make the rounded path selectable in outline mode? Not an Illustrator whiz so use use small words and speak slowly.:)
You have the objects corner radius set as an effect. You need to expand the object (object --> expand appearence) to see the round corners in outline mode.
