K
kala
Guest
Hi
Pls find attached image which has very fine thin lines with vignette effect filled with strokes.. (Illustrator File)
When we output this file for plate @ 175 / 200 / 150 lpi screen ruling this image got broken / pixelleted / not smooth / not sharp as per the image...
When we output the same with other service company the image looks sharper and fine no break at all exactly comes as per the file..
We used kodak plates with lotem 48 diode... Other service company has Heidelberg ...
Is the problem related to file or plate ???
Hope If its the file problem then the other service company will also face the same problem ??
Need anyone advice to sort out this issue..
regards
Kala
regards
Kala
