aditya deshpande
I am using Konica Minolta Bizhub Printer. Specifically in case of patch work job print appears foggy or can say some pattern appears in it. So i checked all the parameters and i found same pattern is there on image transfer belt. I think this fogginess or pattern formed on it because of moisture.
So i want to know that, how to clean this image transfer belt? What chemical should i use? I searched internet and i found Bestine is used for it. But it is not available here. So do suggest what to use for cleaning.
Regards,
Aditya
Regards,
Aditya
