Image transfer problem from RIP to ECRM Stingray 52/63 Imagesetter.
natiqur
Dear Sir,
I am in a trouble with ECRM Stingray 52/63 Imagesetter. When I output a job from the RIP, it shows " %% Failure opening SCSiPel driver. %% Imager not found on SCSI bus. Powered off ? Not connected ? " on the RIP. I am using RIP 6.4 version. I have already replaced SCSI Card of the PC and SCSI connecting cable from PC to ECRM. But no result. Please advice. I will be ever grateful to you.
Basit
Make sure the imagesetter is on Serial mode.
Can you see the stingray in the device list on the PC.
natiqur
Dear Bast,
Thank you for your reply. The Problem has solved after replacing the SCSI Card of the PC. Before it was Adeptec 2940UW. Now it is working with Adeptec 2944UW. Do you please suggest me about how to replace the SCSI card instead of Adeptec 2944UW. I want to use another SCSI Cards available in the Market. Please advice me. Thanks.
Aliwakekani
HIE
AM ALSO FACING THE SAME PROBLEM BUT NOW MINE IS SHOWING :
%SCSI serial argument out of range
%SCSI failure during serial read
WHAT CAN BE THE PROBLEM
InSoft
Learn more..
