Imprinting preprinted sheet on v700
donp
A customer asked if we could add a couple words to an already completed print job. Space was not a problem so I offered to run the printed sheets through as a 2nd pass.
Job ran fine at first (we had crop marks to hit) but then register moved 1/8”, ran some more, moved partially back, ran more, etc. Register didn’t appear to bounce randomly.
Here’s my question: does the Canon v700 make on the fly register adjustments and if so, is it affected by prior printing? Virgin sheet register is rock solid. Coverage is light.
I had a similar issue on a Konica. It's usually one particular element that it sees. I could often get around it by running the job 180 so it's looking at a different area on the sheet.
That thought crossed my mind but never tried it. Thanks for the info. Any way to know what it’s looking at? I asked our service guy but he didn’t know.
I'm sure it's near the lead end. Don't remember which side it uses for registration, though I think it was the non-op side. It was usually a solid with straight edge. Even a 3/4" square could do it if in the right spot. Do you have a media option for preprinted? That can alter the sensitivity, or change the sensor timing on some machines.
