wonderings
I am using indesign CS4, latest updates. Is there away to have indesign create an .inx file when it packages a job? I want basically packaging to work as it does, but to add an .inx file as well as the .indd file.
This sounds like something a script could be created for. Unfortunately I don't script for InDesign. You could check out the InDesign User to User forum or the Adobe Resource pages.
Just curious, why do you need a .inx file saved out?
When exportint to INX i found that Indesign will export to inx even when variables are used. To create a file that InD 3 can open you need to search for variables and convert to text. I don't know of other issues (yet) that would make the inx impossible to open in InD 3. Would it be possible to add converting variables in such a script? (well I know yes it is possible, I guess I'm asking for somone to help come up with the code)
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
