UV Lamps, are they all only lasting 500hrs, End of press and interdeck? If they are all failing at once maybe a power supply issue, Have you changed lamp supplier recently? If you are buying them through Komori (Nordson) maybe they should come in and have a look at the issue.
I have only replaced IR lamps when they got broke, never seen any wear out and they cost a bunch
