Kodak 800 Platesetter 8up, Can't do 4up plating?
nshadab
Some one telling me, that Kodak 800 Platesetter 8up, Can't do 4up plating?
Is that true?
Derek & Kevin would you mind throwing some light on that?
Many Thanks, Shadab'
Is that true?
Hi Shadab -
The Magnus 800 can do 4-page plates too. It can even do 2-page plates. Here are the minimum/maximum plate sizes:
Maximum plate size:
around drum x along drum
950 x 1,162 mm (37.4 x 45.7 in)
Minimum plate size:
around drum x along drum 330 x 305 mm (13 x 12 in)
There may be some additional limitations if you're using an autoloader, but it can still auto-load 4-page plates.
See this page for more details: KODAK MAGNUS 800 Platesetter - Kodak Graphic Communications Group
Kevin.
EDIT: adding info about Trendsetter sizes:
Trendsetter 800 can do even smaller plates:
Maximum plate size:around drum x along drum
Standard:
838 x 1,143 mm
(33 x 45 in) Auto Unload:
838 x 1,118 mm
(33 x 44 in) Autoloader:
838 x 1,118 mm
(33 x 44 in)
Minimum plate size:around drum x along drum
267 x 215 mm
(10.5 x 8.5 in) 383 x 270 mm
(15.1 x 10.6 in)
Manual unload:
267 x 215 mm
(15.1 x 10.6 in)
Manual load and unload:
305 x 215 mm
(12 x 8.5 in)
See this page for it in a nicer table: http://graphics.kodak.com/US/en/Product/computer_to_plate/8_Page_CTP/TRENDSETTER_800_III/default.htm
