Probably smooth and seamless transition from fm to am structureWhy SX rather than CX?
One of our large customers wants to print with a hybrid screening.Why are you considering this screening? Is there a press problem you’re having? Why SX rather than CX?
He does not like stochastics.
As far as I remember from the presentation at GUA, this Maxton SX is a more modern way of screening and provides a smooth transition from FM to AM in highlights and from AM to FM in shadows.
Perhaps I misunderstood the presentation, but the dealer and the Kodak itself have little to no information about successful implementations of Maxton SX and CX.
What exact problems on press are you reffering to?
Thank you for quick response.
The point is that customer wants high LPI AM-screning (300 lpi and higher) and specifically don't want Staccato screening (which we have (20 u) and regulary use).
We use Kodak Magnus VLF (with Square Spot) and Sonora X plate.
This DMS (Digitally Modulated Screening) sounds something like what your customer may be referring to as it’s basically a hybrid combination of both AM and FM screening together. It’s called Auraia and if you check the website, you’ll see that it can be used in almost all CtP imagesetters, and with most plate types, as well.
Something I thought was especially interesting is what they’re calling a ‘stochastic rosette’.
Auraia DMS - Hamillroad Software Limited
Quad has been using Auraia DMS for more than six years across its global heat-set printing operations, and today Auraia DMS is its screening technology of choice. Auraia DMS (Digitally Modulated Screening) is a patented intelligent screening technology designed for the lithographic offset p ...www.hamillroad.com
@gordo
It might be not related to this topic, and I have question about process control, especially in prepress when I make plates with very high resolution (more than 300 lpi with AM, or 10 micron with FM). What do you think about the acceptable tolerance for plate dot area in 1%, 25%, 50% and 75% area? What the number should be?
In my printshop, we print sometimes with screening Maxtone AM 300 Lpi in some jobs, but the tolerance for plate process control is a question that I need your advice. What is the good number based on your experience?
Thanks and regards,
Delta E
