One of our large customers wants to print with a hybrid screening.
He does not like stochastics.
As far as I remember from the presentation at GUA, this Maxton SX is a more modern way of screening and provides a smooth transition from FM to AM in highlights and from AM to FM in shadows.
Perhaps I misunderstood the presentation, but the dealer and the Kodak itself have little to no information about successful implementations of Maxton SX and CX.
What exact problems on press are you reffering to?
Note - I was on the original creo/Kodak screening solutions development team. I do not work for Kodak.
Maxtone is the name of Kodak's AM screening system.
The variants Maxtone CX, Maxtone FX, and Maxtone SX were originally developed for flexo printing. Traditional flexo plates have limitations in the minimum dot size that they can hold. The result is a harsh tone break in the highlights and shadows. CX, FX, and SX are conventional AM (Maxtone) screens that were designed to overcome that inability of flexo plates to hold small dots. They do this by constraining the highlight and shadow dots to the minimum dot size the imaging system can reliably hold. To render areas of tone lighter or darker than the system can image, dots of the minimum imageable size are removed - fewer dots - rather than making them smaller - results in lighter tone areas. CX, FX, and SX are variations on how that is accomplished as well as what happens to the remaining dots.
Effectively the halftone screen is compromised in order to overcome resolution limitations of the (flexo) imaging system.
CX, FX, and SX are NOT a "more modern way of screening". They are technologies designed to overcome imaging resolution limitations. As a result, every vendor that is involved in flexo offers a comparable work around. One way that vendors of this class of screening distinguish their offerings from their competition is how much control printers have to modify the screens as well as how well they handle the transition from the conventional AM part of the tone scale to the minimum dot size part of the tone scale.
CX, FX, and SX should not be needed in an offset environment since the plates, laser imaging, and press normally do not have the resolution limitations of flexo. If you have an offset plating/press which cannot maintain halftone dot sizes smaller than, for example, a 5% tone then you need to solve that problem rather than compromise your printing with a hybrid screen.
Your dealer and Kodak may not have any implementation information to give you simply because this class of screening is not usually needed in an offset environment. They may have examples for a flexo environment - but that experience wouldn't be of any value to you or your customer.
Your customer is misinformed about screening (including "stochastic").
