canadian printer
Our company has bought a new 10/c komori . Just wondering if nay of you have been to Chicago for the training and what it's like. Also how you like running a Komori. Have only run a Heidelberg . Cheers
If you turn off the delta dampening the picture framing and plate ware will disappear. If that doesn't do it then you must not have the same plate to blanket pressure as the Heidi.I am in the same boat as all of you. All said about Komori is true. But My company has had quite of bit of sruggles the last 10 m0nths it has been up and running. I have alot of long runs, 300,000 +. We have had troubble with plate sensitivity. plates only lasting 40,000 impressions. Also ink build up on the chrome and meetering rollers. major picture framing. We have gone through several inks and chemistries to finaly get a handel on it. I have a 2000 CD 102 right next to it that you can put any ink and etch into it and it will run. I am almost convinced that Komori dose not excell in long runs. On a 40" sheet always a struggle to keep the ends free from dry up. It is not like the Heidy, set it and forget it.
Have any of you experinced this yet?
How is this going for you Reyes1377? We have been having long run issues as well and have tried many different inks, fountain solutions and calcium fixes and are now trying different plates. After about 40k the non image area of the plate begins to take ink. We are currently running the Kodak Electra xd plate. Which fountain solution have you settled on?
