Any inker applied matte varnish should not only give you a matte appearance on images, but also offer a velvety like texture to the surface that it's covering, as long as you dont apply too much spray powder. If you run too much powder the velvety texture will dry to a sandpaper like texture. If your not well versed with the application of these types of inker applied varnishes, you should know that running a thicker film of varnish will offer a more matte appearance and a more velvety feel, BUT will become higher risk for blocking and setoff. If the run is short and its in the budget running varnish offline will give the best results. You could even run a double hit of varnish if its being done offline but I would run small lifts and recommend caution for the ultimate in matte appearance and soft texture.
