Looking to buy new CTP
Achieve is old but a solid machine. Autoloader is easily disconnected.
Fuji machines are good especially if made by screen for them.
New Kodaks, not so Impressive, Constant Slip sheet jams!
Fujifilm Luxel T-S1 IS AMSKY CTP
ECO3 Avalon C8 - 30E IS A CRON CTP
Betwen this two option Amsky is better, more stable and have low usage of mechanical movil parts
Amsky diodes is more easy to found in the market, but somes new Amsky CTp use one LGV valve, and have only one diode, this model use one new posicioned system called linear motor, and this combination is the last technology, and have same cost of old technology.
Amsky diodes is more easy to found in the market, but somes new Amsky CTp use one LGV valve, and have only one diode, this model use one new posicioned system called linear motor, and this combination is the last technology, and have same cost of old technology. If you're comparing and only need the most conventional on the market: 2400 DPI and a maximum of 175 or 200 LPI, Amsky (Luxel T1) and CRON (AVALON C3) will meet your expectations and offer a cost-effective solution. The key is, which of the two representatives will provide you with the best, most affordable, and most stable after-sales service?
Now, if you need higher resolution in the future,
3600, 4000, or more DPI for special applications.
You should consider a Kodak or a Screen directly.
