Lotem 800v2 Focus Motor
Repro_Pro
Does anyone know/remember?
Startup fails on Focus Motor error.
The focus motor shows an invalid/out of range position.
How can one reset this value to zero in order to re-calibrate.
In other words, where is this value stored?
Is it on one of the cards in the E-Box?
Urgent expert advice needed!
TIA
Magnus59
TIA
Have you cleaned the lens cover? Not just wipe while in the machine, but remove the lens cover and thoroughly clean inside and out. A build up of dust can cause this error.
Repro_Pro
Thank you Magnus,
I followed your instructions but it had no effect on the focus position.
I shall now try to swap the Local boards, as suggested by Pach in a former discussion.
I shall report back later.
Repro_Pro
I replaced the Left Local Board twice with spare boards I have.
Each time the focus position showed a different value, all out of range.
These tests lead me to believe that the Focus Position values are stored on the Local boards.
How can I reset this value?
Repro_Pro
Update:
Plugging in our spare Focusing Motor Unit fixed the zeroing problem instantly.
So far so good, thanks for everyone's interest.
