Lotem800v2 mismatched plotter exposure lines
skymaster
Hi
Error message is as written below
mismatched plotter exposure lines required =2928 ddb counted 3648
Tsp,ddb,sister board,-5 volt power supply are allredy replaced
and still same error
does somebody has an idea
Hi
change the tsp cable....
Hi
after replacing the DDB board did you reload the DDB Hex file with all the doors CLOSED?
hi
hi
Hi PACH
I didnt replaced ddb before and it is not written in procedure
Can you explain and can you send it to me the ddb hex file
Hi
YOU SAID THAT THE ddb WAS REPLACED
ANYWAY, I PRESUME THAT YOU KNOW THAT THE DDB BOARD IS IN THE L BOX (BEHIND THE LHS DOOR.)
AFTER YOU REPLACE THE BOARD OR WANT TO LOAD IT DO THIS:
Make sure that the L-BOX main power switch is ON.
Open the application and make sure that the machine is in READY mode.
GO TO HARDWARE /Boards/DDB card.
NOW PRESS "CONNECT" button IN THE SCREEN IN FRONT OF YOU
NEXT PRESS THE "SEND" . IT TAKES A LITTLE TIME FOR THE LOADING TO BE COMPLETED.
WHEN THIS IS DONE OPEN ANY OF THE DOORS AND CLOSE IT AGAIN WHEN THE SOLENOID RETURNS TO ITS NORMAL STATE
NOW OPEN THE DDB BOARD AS YOU DID BEFORE AND IF IT HAS LOADED OK YOU SHOULD SEE THE FOLLOWING AFTER YOU PRESSED THE "CONNECT" BUTTON IN THE "STATUS REGISTER -0" 000 FF FF F7 F7
IF YOU DO NOT GET THIS YOU WILL HAVE TO REPLACE THE VERY EXPENSIVE DDB BOARD.
PS. BY THE WAY WHERE ABOUT IN THE WORLD ARE YOU?
thanks my friend
thanks my friend
Hi PACH
Thank you very much
it helped me
