How? We have same blankets on all presses. We've tried changing with new ones (all 4 at ones with packing of course)I suggest you try changing the blankets. This may solve the problem. Or at least you will eliminate a variable.
No, we didn't. Because it's hard to control proper amount of reducer.Have you tried adding reducer to print 'fuller' to match the other presses?
How about this- you could increase the laser power on plates for that machine ( to increase dot size) or try another plate manufacturer that would increase dot size without changing the laser power.No, we didn't. Because it's hard to control proper amount of reducer.
You're joking, right? I was talking about interchangeability between 4 same presses.How about this- you could increase the laser power on plates for that machine ( to increase dot size) or try another plate manufacturer that would increase dot size without changing the laser power.
. . .a little testing-
Dan 412.889.7643
How about shut the press down and distribute the work to the other three presses until you can get a authorized Roland mechanic in there to figure it out?You're joking, right? I was talking about interchangeability between 4 same presses.
Why on earth should i change laser power where i can easily change curves for the same outcome?
And again - tips and tricks on how to overcome it locally is not what i'm looking for.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
