Hi Guys, The low migration concept of the conventional inks is that: It should fulfill the requirements of the organoeliptic ( odor and taint) and migration. So the odor comes out drying of oils which needs metal catalyst so to get rid of this fact the LMQ inks are designed without catalyst ( or dryer) so actually LMQ inks do not dry rather settling down the cartoon layers so after printing LMQ water based OPV is mandatory otherwisw all the sheets stick on each other, OPV helps the ink settling down and also not pick the surface,also helps rubbing. For migration side, petroleum based hydrocarbons are ( or mineral oils) are migrating so LMQ inks are designed with suitable vegioils ( which do not oxidise). Therefore, while using a wash, it then should be suitable for LMQ, not contain any petrolum based derivatives ( since normal washes) do have. Foun solution contents also selected as sıitable for LMQ systems. You should e very careful for LMQ prints, since for swiss ordinance, the migration limit is 10 ppb ( 0,01 mg / kg food) and ink+opv does not mean that you can guaranty the LMQ printing, LMQ concept is a package of ink+subsrate+printing environment+press auxiliarries. If something missing the concept from this 4 to LMQ, then you will be in trouble to be detected in analytical measures.
For UV inks, it is still valid except 2 tnigs: for OPV you shoul replace LMQ UV coating and the inks to LM UV inks which do not contain benzophenone or its derivatives of which potential migrants whivh corresponds to the hyrocarbons of conventional inks.
I hope these help
