tekcontrol
An Agfa LP 82 Ultra lithostar has permanently error Water Pressure low, any ideas about the problem?
The problem is the line water Pressure or the defective water pressure sensor located under the processor where the water line enters or connects to processor water hose. The sensor can be bypassed by disconnecting 2 wires from the sensor and connecting them together. In some cases, depending to the type of the sensor disconnecting single wire will resolve the issue temporary.An Agfa LP 82 Ultra lithostar has permanently error Water Pressure low, any ideas about the problem?
Thanks, for your help, I'll try it.
