Is it an older heidelberg press by any chance? Sometimes you can correct this issue if its happening on the tail of the sheet by adjusting the compensator. If your not familiar with this adjustment its a small cam right in the center of the ranger drum. This can be adjusted to control fan out on the tail of the sheet. The biggest problem is that very often you find that press operators will move this adjustment and not put it back to its zero position which winds up wearing it out.
