oxburger
Gathering your thoughts here or what your company does regarding templates. When creating a 16 page 8.5 x 11 saddle stitch book for example, do you use a master template that you link to, or do you save a template under each job that you have on your system? We have master templates, but we usually only use them as a starting point because when our impositions are created by the higher ups, they constantly change gripper, color bar placement, or the paper may be different, etc. It makes making master templates essentially useless, so were forced to use it only as a starting point and then alter it and save it under the job number it's used in. Do any of you use master templates for imposition? or are you in the same boat as me where nobody can make up their mind and make it easy on everyone? It's not a huge deal as it only takes a couple of minutes to alter a template to fit a job's specs, but we now have a gazillion templates on our server.
