Mgi dp60 - static
Cormac Deffely
Hi
We have recently purchased a DP60 press form MGI and attempted to run a plastic
job (approx 1250 13 x 18 sheets). We encountered major static issues and had to sublet the job to hit the deadline even thought the substrate we were using has "outstanding
anti-static properties" according to the spec sheet!
Does anyone who is running a DP40 or DP60 have any advice that they would be willing
to share?
Many thanks Cormac
Dear Sir,
May I know which is the material and the spec used for printing on your DP 60. We do have a Meteor Dp 60 installed in India.
Awaiting for your reply.
Dinesh.
Hi
How do you like the machine? How is it running on paper? Tried it on heavyweight surfaced stock? Any info is appreciated.
Hi Dinesh,
Apologies for the delayed response. The details I have re. stock and settings are as follows
__________________________________________________
Stock Type:
JPP T-Grade (or Plasnet T-Grade) stock
Manufacturer:
Nan Ya Plastics Corp (Taiwan & USA)
Nan Ya Products Page
Nan Ya Plastics Corporation USA
9 Peach Tree Hill Rd.
Livingston, NJ 07039 (Map)
Phone: 973-992-2090
Fax: 973-716-7470
The info below is from the tech data sheet supplier by the Paper Merchant;
Technical Info: PLASNET T Grade is a single structure White calandared Polypropylene Sheet Especially formulated to feel and handle like conventional paper. Its unique
Surface treatment enables printing via screen, offset, flexo, gravure & thermal Transfer.
Titanium dioxide added.
Characteristics
- Excellent printability and adhesion
- High tear resistance
- Outstanding anti-static properties (!!!!!!!)
- High opacity and whiteness
- ISO 14001 EMS
The DP60 Settings we are using are as follows
Substrate type = Synthetic
Actual Substrate type = YUPO Synthetic FPU 200gsm
Settings:
Fusing = 25
Back up = 25
THV = 50
IR Off
Anti-static setting ON
As we are new to this press we are happy to share any information with you regarding
problems, fixes, success stories, etc - anything that might be of use/benefit to both
you and us if this is of interest to you?
Thanks & best regards
Cormac
hi
hi
Hi Dinesh,
Stock Type:
Manufacturer:
Phone: 973-992-2090
Fax: 973-716-7470
Characteristics
- ISO 14001 EMS
Settings:
Fusing = 25
Back up = 25
THV = 50
IR Off
Cormac
Dear Sir,
I'm sorry to reply you so late. Dp 60 Substrate settings for PVc of 290 microns.
The profile set is :
Front Fusing : 35
Back up : 35
THV : 70
IR : OFF
Anti-static setting :ON.
Substract we are using for Ineos,India and China. We are not facing major problem of static.
I would Like to know abut delaminating of cards after punching ? Does yours cards get peel off ? Do you use any coating to prevent from Delaminating
Do you have MGI s product of Presscard pro and Punchcard pro.
Thanks and Best Regards,
Dinesh.
Dear Sir,
Front Fusing : 35
Back up : 35
THV : 70
IR : OFF
Dinesh.
Run a static tube in-line from the blower compressor. That will help durring the feeding. Turn up your humidity in your place as well
