UK Printer
Morning All,
we have a Mimaki JV 130 Print and Cut, i changed the blade in the contour cutter and now its out of position on a cutting job by about 2 - 4mm.
The inaccuracy is across the width of the machine rather than down the length of the sheet, has anyone got any ideas what could cause this.
The job is 'creeping' out of fit as it travels away from its zero point, so by the time we at its furthest point from the start its about 2mm too far over and at its zero point around a mm too far the other other direction and pretty good in the middle.
We used to have this problem when we first got the machine, probably something to do with the blade being new.
Any help would be appreciated.
Tim
Tim
