N-propyl alcohol versus Isopropanol alcohol
2 in 1 fount is 80% Propyl Alcohol cas #71-23-8
Nothing wrong with that, if you dose it midway between what is recomended, you have 8%NPA and 2% actual fount being dosed in automaticly out of one drum
There is no need then to have IPA on the premisis which as you know has an extremly low flash point,,
The flash point of neat NPA is much higher then neat IPA, But since the NPA comes mixed with the fount, the flash point is even higher. And not to mention neat NPA is 20% lower VOC then neat IPA.
Look don't get me wrong, if there was an alcohol free fount out there that worked as good as this on polyester plates we would be using it,
A lot of people ramble on about the health benifits of their IPA free printing but if they took a close look at some of the MSDS, data that comes with that fount, they might be a little shocked to know that it's just as bad for you, then in some cases you have the printer adding IPA to help when their having problems in which case makes it even worse for the printers health.
Tom,
Re IPA v N-propyl
Re IPA v N-propyl
Tom - you are wrong -- Isopropyl Alcohol (IPA) the pure "Anhydrous" 99% version ---
IS Miscible !!! Indentifier # CAS [67-63-0] and most important its Viscosity is ---
2.86 cP at 15 C
Regards Alois
Alois, your correct, seems I got it the wrong way around
IPA water miscebal
NPA Solubility:
Infinitely soluble
n-propyl Viscosity (20 ° C) 2.256mPa
I'm just wondering if your running IPA at 5% with a 2.86 cP at 15 C viscosity, would the fount still be more viscous then running with 8% NPA ? not sure how we could do a test to find this it.
Alois, most printers are trying to cut or elimnate IPA from their founts, and yes a lot of printers have managed to do so, but it is with the use of metal plates.
I would like to hear of anyone running IPA free on polyester plates, or even up to 5%ipa, on polyester plates. if there is anyone here that does, tell me can you run between 13500 - 15500 sheets an hour with fine screen rulings all year round, be it a hot summer day, or not. PMS colours/cmyk/gold/silver/fluro
We had been able to get down to 3% - 5% IPA, but our water window had shrunk greatly, and there was a fine line between working and not working, and the quality of work was lower then what we are producing with this fount.
So the bonus of this NPA, comes in, you want to run at 5% IPA but print quality isn't as good as it could be,, you switch to 2 in 1 with NPA in it, you can then run it at 8% and have fair superior printability, and your voc emissions are no higher then the IPA at 5%
Honestly this is the last post I have about the stuff, I will post back in a few weeks to let on if we still love the stuff,
Tom
2 in 1 is 80% VOC.
2 in 1 is 800g/1 Voc or 8g/l per each percentage point used
ipa is 1000g/l VOC or 10g/l per each percentage point used
8% 2 in 1 is 64 g/l voc
5% IPA IS 50g/l voc
Green printer, you failed to add the VOC level of the IPA reduction/replacement fount to that IPA voc level, some of those founts have up to and beyond 30% voc levels.
so lets say a dose of 30%voc fount at 3% + 5% IPA theres 59 g/L VOC Even though its slightly lower then the 2in1 fount, your VOC emission levels should still thereticly be higher, given IPA's vapour pressure is double that of N-propyl
not forgeting the vapour pressure of 2in1 is Vapour pressure : 10 mm of Hg (@ 20•C)
N-propyl has a Vapor Pressure (mm Hg):
21 @ 25C (77F)
versus
IPA
44 @ 25C (77F)
Please do correct me if I'm wrong, but the lower the vapour pressure the less it readily evaporates,
there for, your getting less of the product evaporating into the air..
Still very interesting stuff though
Luke.
Lukew
A VOC is called that because it will evaporate. It doesn't matter about the speed of evaporation.
What doesn't directly evaporate into the air during production will be absorbed into the printed substrate and then it will evaporate later.
Ever opened a box of printed material that has been sealed.
When you open the box it has an oder and smells, that is VOC's being released that didn't evaporate during manufacturing.
It always evaporates, just where is what is different.
Ahh I didn't know that,, this whole enviromental stuff is new to me.
so it may be healthier for the pressman, but not particully any better for the environment?
As I had first stated I was more interested in running the NPA with the fount we were using, at say 5-6%Npa.
I said -------------
I said to the Boss we should have stayed with the "Stones" never mind these new fangled Polyester Plates !!!!!!!!!!!!
Regards, Alois
We had been in contact with our suppliers, and none of them sold N-propyl so we had two options, keep using our current fount, with a dose of 3.5% IPA or give the 2in1 fount a trial,
Trialing of the 2in1 got the nod, and it has been in the press for 2 weeks now,
Our main reason for giving it a go, was the fact that if it was to work we no longer had neat IPA on the premisise, + if it lived up to all its hype it would be a god send.
Our current fount had given us the ability to get down to 2% IPA, but as the days started getting warmer, this % number started to increase, to a point were we hovered between 3.5% - 5% IPA and up to 7% on tricky jobs, Our water % feed rate was starting off at +50 - 60 and ending as high as 75-80 on some PMS coloured jobs, which was simply too high and we could see that come summer time it would only get worse.
also the water feed % rates was unpredictable, you could print the same job the following day and have totaly different settings, this of course lowers the acuracy of cip 3 as the different water % feed rates plays havoc with ink density.
So in comes the 2in1 fount. dosed so we get a reading of 8% NPA
our water dials are starting on 35% and ending no higher then 40% by the end of shift with only the last deck near the IR dryer going up to 42 % on the odd time. the last few days they have ended no higher then 38% These figures are with both cmyk or PMS inks.
As you can see with such a stable water feed % rate, it gives you the ability to fine tune cip3 even further,
whether we're going from a light coverage job to a full coverage job, our water feed rate is near the same, and we're at correct density within 30 sheets.
The plus's we have noticed
- no picture framing (ink buildup on the impression cylinders) we used to have this problem with all the other founts we have used
- minimal water needed to keep a smear free print, so much so we have now been able to run in intergrated mode when needed, which has nearly completly eradicated our banding problem on solids without any emusification problems
- there is more detail in our work now, as even the finest screens are open, looking at the dot structure under a 40X magnifying glass shows us why, its simply holding its shape and is incredibly sharp.
-We are using less ink to achieve density, especially with PMS colours. (before hand with low IPA we did strugle with certain colours and had to run an incredibly high water % feed to stop scumming up in screens)
- Start ups are fast and scum free.
-registration is much better, less water means less distortion of the sheet.
- drying time has improved
-no more cording from the metering roller
Anyone that runs or has run polyester plates would know that they do strugle to hold fount esspecialy when the temp gets up towards the end shift, but this fount seems to knock that problem on the head, and allows the plate to run near identical to metal plates.
I had a run of 30000 sheets 2 colour PMS,now normaly by the end of a run lenghth like that I would have increased my water feed rate by at least 25 points, but with 2in 1 I had only rasied it by 5points.
John, so fair your concerns of emusification by way of the n-propyl being too good a solvent has not arose.
I feel one of the main reasons it won't is because you have the ability to run such a fine amount of water, that there is very little water feed back into the ink rollers
We printed one PMS colour which normaly gives us emulsification problems as a test, and we were amazed at how sharp the print was. with no emuslification.
I will say that, while we are not as low voc emision wise as where we were at, our print quality has greatly improved,
Its not often that you can put a new fount in and straight away, throw your hardest jobs on the press for a trial, and have it just simply work, effortlesly bonus!
I can now honestly say, I like printing with poly plates, and up until now, you would never ever hear me saying that..
2 in 1 Fountain solution
Hi Tom, we are pleased you are "blown away" by our 2in1 Fountain Solution!
We have recently started using that 2 in 1 fount, and we are simply blown away by how well it works, expecialy on polyester plates. Its set to dose so we get 8%NPA and 2%fount which emissions wise roughly equates to running IPA at 5 -6 %
We had trialed numerous founts ranging from your IPA repacement to normal founts with a dose from 2.5% up to 10% IPA, and this product simply outperforemed all of the other founts.
Its ability to keep the plate wet, keep fine 95% - 97 % 175 line screens open with minimal water is amazing. And thats with polyester plates..
Our back cylinders are staying clean and we get no more anoying picture framing on the cylinders which is normaly just a hassel to cleanand more downtime
It prints a much sharper dot compared to the other founts we had trialed
Drying time has been slashed, and there's simply less water needed and less ink needed to achive density, As you know you generaly need less ink to achieve density when going from say a fount with 10%ipa down to below 5% IPA well with this fount your ink keys are closed even further..and your running lower water settings even when compared to 10% ipa
We have always had a problem getting band free solids due to press design(water roller diamaters too small,) In which case if you run metal plates you get very little because of such a low water setting needed to obtain a scum free image, but with this fount, on poly plates the banding is nearly totaly disapeared a huge improvement from what we had.
As I said we have only recently begain running this so I will give a heads up down the track, but so far its simply briliant..
So for those that say it can't work, simply haven't run the 2 in 1 product or have a hidden agenda.
Also its fogra approved and contains none of thr nasties that some of the IPA free founts contain.
I just wish I had come accros the product sooner,
Tom
Hi Alois, yes 2in1 is manufactured in South Africa and distributed throughout Africa, Australasia, Europe and the UK. We are having tremendous success with this product on polyester plates. For information please view BM Management - Specialist Chemicals for the Printing Trade
Hi Lukew, are you using 2in 1 Fountain Sol. from the South African Company - BM Management SA ??????
I have no experience of printing from Polyester Plates !!!
Regards, Alois
Hi LukeW, Thank you for quoting an honest reference to our product. Regards Carol Kirk BMM Print UK.
Beware 2in1fount solution!!!!!
NPA in its raw state is a 100% VOC, no different to IPA. Also, check the FOGRA website,
2in1 has a high nitrate content, ph should be more than 6.5.
Zoros, please do tell..
What is there to be aware of??( I have had some of our other suppliers say the same thing, but none we're actualy able to tell me what I was ment to be aware of, or LOOKING out for..I'm sick to death of people baging something but not having anything to back up there comments)
Yes I've seen the fogra listing of high nitrate before.
Nitrate?? 1000+ppm exposure level, is it not?
are we talkin sodium /potassium/silver nitrate
Are you implying the ph level of 2in1 needs to be kept over 6.5 for a certain reason..or is it that nitrate deteriates the machine????
I was having a chat with another printer I know, and he was rambling on about the fact that both IPA/NPA, should be eradicated from the press room,, I asked to look at the msds of his fount..
one of the main chemicals in it was
2-BUTOXYETHANOL
Airborne Exposure Limits:
-OSHA Permissible Exposure Limit (PEL):
50 ppm skin
-ACGIH Threshold Limit Value (TLV):
20 ppm (TWA), A3 - Confirmed animal carcinogen with unknown relevance to humans
Why arn't there alarm bells ringing with such chemicals used in fount solutions with incredibly low PPM exposure limits, please don't tell me there's anyone here that thinks 2-Butoxyethanol is safer.
Heres a pdf, that covers some of the health effects and exposure ppm levels, of all different glycol ether's a few of which can be found in most popular IPA replacment fount solutions
http://www.cdph.ca.gov/programs/hesis/Documents/glycols.pdf
Beware 2in1!!!
Beware 2in1!!!
Did you mean deteriorates? Perhaps the explanation for the FOGRA caveat should come from the manufacturer. At least the msds you quoted from didn't have any 'trade secrets' to hide behind. Could it be there are constituent parts that may not be user friendly? I merely ask the question, no need to be hostile!
Zoros,
Sorry for being hostile,, it's been a very long day, and as I said your not the first to say beware, to this particular fount,, but gave no clues as to why it is so bad..I personaly feel to come out with such statements you need to be able to back it up with genuine reasons why.
Yes a lot of the founts hide behind the "trade secret" doesn't seem right to me,, I feel an msds should mean full disclosure or any chemicals, especialy harmful ones.
I wouldn't mind buying a nitrate tester just to see the levels in it, once its mixed with water,
"Did you mean deteriorates?" yes I did, were you implying that the fount needs to be kept over 6.5ph?
I still feel we have a healthier pressroom running 2in1 with an actual alcohol reading of 8% then compared to if we were running between 4.5% - 6% IPA with founts containing certain glycol ethers..
No you are not running a greener pressroom. NPA is no different to IPA. It is still a 100% VOC. Put it this way: If we mix IPA and fount to 100litres of water we would get 10 litres of IPA and at a 2% dilution of fount solution. This would mean IPA dosed at 10% @ £1.10p to 100 litres of water costing £11.00p. Fount solution dosed at 2% @ £2.50p per litre would cost £5.00p. Total cost for a mix is £16.00p for 100 litres. I hear that 2in1 is dosed at 10% and at a cost in excess of £2.00p per litre. That is AT LEAST £20.00p per 100 litre mix. £4.00p AT LEAST more expensive per 100 litres I can sell IPA and decent fount solution for!!! Listen, 2and1 is not a greener product than IPA/fount, For sure, not cheaper from what I hear. Do the math; this product can cost you dear. I also know of many places that have removed 2in1 for problems of steel dampening rollers accepting ink, also the smell of the product, I know IPA is not good but I have been told this is particularly nauseous. I have problems with manufacturers that will not reveal all of constituent parts, no matter how small, I will not deal with them. This is why I say beware. Ask relevant questions; ask for documentation, FOGRA is an important organisation that conducts accelerated corrosion tests to ensure you do not put anything into your machine that could cause it long term damage. This is why Zoros, who does not lie, asks you to beware of 2and1 fount solution.
Zoros,
I was lead to believe that 2in1 emitted les VOC's then a fount with IPA in it,, because NPA has a much lower vapour pressure..then IPA.
So your saying that running 2in1 with an alcohol reading of 8% is not equivelant to running normal fount with 6% IPA,, surley if you mix both at 8% the IPA would emite more due to its much higher vapor pressure
Two exerts taken from PNEAC forum regards low vapor pressure blanket/roller washes
"According to EPA's ACT for Offset Lithography, a cleaning solution with a composite VOC vapor pressure of 10 mm Hg at 68oF is equivalent to a wash containing 30% by weight VOC. There are some newer washes that have vapor pressures less than 10 that can be explored for use."
"Low vapor pressure washes, those with less than 10 mm Hg at 68oF, have been used with good results by printers. While they are considered 100% VOC, they result in lower VOC emissions because they do not readily evaporate. "
How is this principle not applied to IPA/NPA?
I will say the only difference we have had to do is wipe the dampning steel down of a morning before engaging the metering roller, if this is not done the steel does soemtimes except ink..(2in1 has a slight sticky residue when it dries)
Also i have to agree this stuff does have a very sweet smell to it..but its no worse then IPA..
We are having an envrionmental audit, some time over the next few weeks, conducted by experts, I will be bitterly disapointed if I find out through them that we have made a backwards step regards to a healthier pressroom and les environmental impact.
We have done the math's and it is not costing us anymore
2in1 is $6.00 L
IPA is $3.50 L
low IPA fount $12.00 L
our original normal fount $29.50 L
Ipa/npa
Ipa/npa
I think this is open to interpretation. 25lts of 2in1 contains 80% NPA but the NPA is STILL a 100% VOC. True, NPA evaporates slower than IPA, but not by that much as it would be leaving residue on the stock material. I do not believe that it is good to compare blanket/roller washes with IPA/NPA. They have different jobs to perform and have no great need to evaporate as quickly. I believe also Voc levels can only be reduced by using less! There are many founts around now that can run quite happily with just 5% IPA provided there is good housekeeping on the press. Indeed, there is one from HDP, now owned by Varn, that claims it runs with 3% IPA. I have not seen this, so I am not so sure.
