-First open the front door. Two philip screw
-Pull up the Cont board Base and clip to the two screws
-Under it, you will see the black cover, remove it #4 allen wrench (4 pieces)
-Please do not touch the lens or the cover will contact the angle 45 mirror.
-Clean all the lens with cotton buds, and the mirror angle 45 going up (you can clean it after you remove the sub-stacker and 4 screws.
-Clean the ND changer miror
-Open the side cover, you can remove the convex lens. please check if it is align with the base holder or maybe some tech guy who clean it the didn't remove some fiber of cleaning material.
-Open the White cap Poligon mirror inside (clean it but do not use any chemical or spray to clean it use a soft cloth or cotton buds.
usually, there are two factors for the unbalance density. First, the FT-3050 and 2nd the film processor unit.
The mention above is ofr the FT-R3050 machine but need to know if it is online or offline
sometimes, the roller and the circulation of chemicals in the developing tank affects the density. Be sure the circulation of the chemical is good.
mostly, the replenisment is in the other side and the circulating pump blow to the other side. this also affect the density. Try to cut 1 meter of film and exposed it in florescent lamp and load/develop it to see the density.
Sometimes the film is expired or more than 2 years ago.
Note: if the laser diode have a problem all the exposure will encounter the problem.
Hints: Laser beam to 45 degrees mirror to ND changer to Polygon mirror to 45 degress up mirror to Convex lens to film.
