Need help with a Metronic OC200 press
Bassfishr
If anyone is currently using one of these presses. I need to know some numbers your press is running at. I need to know what the numbers for your dryers are. ( amps, volts ) Our dryers are running at 10A & 140V. According to the operators manual they should be at 16A & 150V.
Also, the bulb mfg specs are for 16A & 150V. Just need some solid numbers from other people running or that know these units...
Thanks....
