Need Help with Pisttop Action
I have a PDF that is a 6up tag for a car mirror and I need to flip the bottom 3 objects horizontally so that they are all foot-to-foot. Seems simple but I cannot get it to work.
In Pitstop (13) I have tried to "select objects in region" and then used the "flip horizontally". No luck. Any advice/help would be appreciated.
jminrod
Do you have any other pagination software?
We would place the pdf in Indesign and treat it as 2 pictures, or we could change the crop boxes and impose the 2 halves back together in our imposition software.
abc
Flip in that version only works on a page basis, not on a selection. Rotate would be the best option I guess?
Select objects in Region is the right approach.
Thanks jminrod I'll keep that in mind for the future. Yes I did stumble upon rotate in Pitstop: 1. Select objects inside region, 2. rotate objects (which put the bottom 3 objects on top of the top 3 objects), so 3. Move by (amount needed). Thanks all.
Color Optimized?
Ink
by Noel Ward, Editor@Large
Color is in demand in all types of documents, making color management a critical part of Digital Printing 5.0. Managing color on one device/press can be an easy task with the correct tools and processes. But managing color to ensure printed pages are consistent and repeatable across the different substrates and color gamuts of toner and inkjet can be a much bigger challenge. Properly implemented color management workflows can help achieve consistent color results across multiple devices. Although many end-customers are claiming satisfaction with “pleasing color,” two challenges are still in play. Link to Article
