PDF Proof workflow
Missed few letters.. Too much work maybe... Everything is ok now. Thanks!
Hi Karolisk
Looks like it's having a problem finding the joboptions fiile. Go through the instructions on my original post carefully. Open the script in a text editor and make sure that the joboptions mentioned in line 124 of the script exactly matches the PDF joboption setting from Illustrator that you want to use. In the script I posted it's set to look for one of the Adobe defaults for the newer versions of Illustrator CS3 or later '[PDF/X-4:2008]' -- including the brackets -- if that exact joboption isn't installed on your system it won't work.
Shawn
