Hi Simon C,
PitStop Extreme is a native PDF viewer and editor, running on Mac OS® X and Windows,
and is aimed at fast and interactive PDF editing and correction in production
environments.
I believe that Neo was Mac only - and there are no things like Global Chnage (I do THAT a lot) or Action Lists (I do THAT to everything)...
I think this is more the upgrade to a PitStop power user - and (ahem) please do note that this is "adobe-less" - that is correct, no need to have Adobe anything installed, as it use 100% Enfocus technology and code -
-- VERY Accurate viewing and measuring
-- Advanced text and paragraph editing in that there is a powerful text editor; even text re-flow is possible by linking text blocks.
-- Transform objects and edit images, such as move, scale, rotate, align or distribute objects it is also possible to edit images. This happens either by replacing complete pictures or by directly using an image editing application like Photoshop to edit and save the image content and instantly see the changes in PitStop Extreme.
-- Document resources Separations, images and fonts can easily be controlled via the resources
panel.
-- Transparency handling
-- Page box handling
Hope this helps - to me, it is a must have - as a developer, I depend on PitStop to see what our PDF image processor actually does and analyse the results.
Michael Jahn
IQColour.com
