Brian Gibson
Hello to everyone.
I'm new to this group so I hope this is posted in the proper location.
We are having plate image wear on our web presses and I am just curious as to what others have done to correct similar problems. The image seems to be physically wearing off the plates. Mostly happens on our longer run jobs at around 100 - 200,000, but it has also happened around 40 - 50,000. Tends to show up on the print in the black first and then the magenta. Wear seems to travel side to side across the plate. Not lead to tail.
In November of 2007 we switched from Kodak Sword plates to Fuji because of wear, and other issues. At first, the Fuji plate ran great until around April 2008 when we started re-plating long run plates again. As time goes on, it seems like the length of run for the plate is getting shorter.
We are an in-house shop that prints both sheetfed and web. The web runs almost 24/6.
Plates are Fuji LHPJ 21.75 X 35 X .012.
Output from Kodak Trendsetter News 50. (2)
Processors are G&J Quartz Z85. (2)
Stochastic screening 36 micron 1200dpi.
Web presses are Goss Community 4Highs, 35 wide X 21.5 cut off, non-bearer. (4)
Ink sequence is KCMY.
Paper is Abitibi BoWater News Offset or Alternative Offset. 10" - 34"
Flint Ink CMYK, occasionally we use some recycled black, made using 300 micron filter.
Fountain solution Fuji Pressmax 14N, mixed with city water 10 gains hard and no additives.
Blankets are 66 or 67 Central with .20 Mylar pack. Plates are not packed.
Any information you can share is greatly appreciated.
BG
BG
