Primesetter 74 -- Problem with punches
chugo
Hello everyone!
I have problem with punches in Primesetter 74.
The Primesetter prints well, but in NT Utility I have lost buttons turn on/of punches.
I tried to restart in DIAG mode and test punches. Punches worked well.
I have no idea what is going are and how to solve problem.
I have this parameters in "Parameter editor"
Punch Action = 0
Punch Advance P0...P11 = 20 or 30
Punch Link P0...P11 = 0
Punch Shape P0...P11 = 0
Could you explain me what are they for, and how it correct?
Punch Configuration = 16 (I think this parameter is correct, because when i tried to change value and restart the Primesetter it's goes to error)
thanks a lot!
  • DIAG PRIMESETTER.txt
  • Punch Config.zip
    Punch Config.zip
PS74 Punches
PS74 Punches
not only the punch link is important, but also the parameters which describe the position of each punch needle. Find a sample data sheet of another PS74 attached. Also check the parameter "Use Punch", if I am right it should be PID 528
Good luck
Hello everyone!
Punch Action = 0
thanks a lot!
Good luck
Thank you for that...
I solve the problem to add values in parameters
Punch link 5,6,7 = 16
FS2P5,FS2P6,FS2P7 = 6650
SS2P5 = 159100
SS2P6 = 375000
SS2P7 = 590900
Regards
