Prinergy 8 and VPS question...
lostmind
We recently just changed over to Prinergy 8 and I just noticed on a particular job that the VPS was messed up. It was missing color out of the background of a postcard I was working on. I went back and previewed the refined pdf and it was perfect and then I made a pdf proof of the Imposition, and it was correct, but the VPS wasn't. I double-checked the settings with my previous version of Prinergy EVO and I didn't see anything different. In fact, I ran the job through EVO and made a VPS there, and it was also correct. Being a printer and relying strongly on the VPS proof for accuracy, I am greatly concerned when something like this happens. Has this happened to anyone else, and were you able to fix it?
Was the missing object a spot color? Also what resolution are you making the VPS? If it is under 800 dpi try running it at 800 dpi.
Is the missing object an image? Vector? If you can get me the PDF I can run it though Prinergy 7.5 and see if it happens there.
