Problem with lamination on flat xerox 3100 color
hmeddahi
Hello
We have a problem with filming. It peels off on the sides and ends up completely removing. Especially when there are flat colors. We print with xerox 3100 700I and 5000AP presses. Hot lamination.
A solution please
Hello
A solution please
Try laminating slower, hotter and increase pressure. And use digital superstick film.
If the job has lot of tint this problem happens,
Laminate it a day after printing and check the temperature, decrease the speed of lamination
WreckTangle
Sounds like the lamination material is the issue. Printed mainly offset books and got into printing low runs for our customers via digital, so we laminated plenty of covers. We outsourced all of our lamination and never had any problems, like Eric said, our vendor laminated the covers with a digital capable superstick film. I'd contact your Xerox rep or technical support and ask for a level 3 engineer, they should be able to help.
kev_24
If this problem occurs in the job, laminate it one
day after printing and test the temperature, lower the lamination speed
