Production Planner Notes
MacTwidget
Worked on a job today and this was in the prepress/press instructions...
"PLEASE NOTE:
THIS JOB WILL RUN SHEETWISE FOR DRYING PURPOSES. BUT
TECHNICALLY, THE SAME IMAGE PRINTS ON BOTH SIDES OF
THE SHEET AS IF THE RUN IS WORK & TURN."
Uh... isn't that a W&Turn?
Do they mean that you will do a makeready for side 1, print, then let the job dry for a few day while you run other work on the press. Then come back and do a second MR for side 2?
That's how I read it arossetti. Before UV we'd occassionally do that with heavy coverage jobs on uncoated stock.
Although, I have no idea if it's still a work and turn or not. I think I'd call it sheetwise, we'd be making two sets of plates anyway.
Yep . . we run that way for some blues and some stocks - try for last run friday - 1st run monday and gum the plates
Maybe they mean that it's the same art front and back? So either way, as a W&T or a sheetwise, you'd only need one set of plates. The note just adds confusion if this is the case.
