Few questions... Using "TruFlow Workflow" / "Epson 9800 Printer/proofer"
1) What is the best papers to use uncoated and coated for press matching proofs off the Epson 9800?
2) From what I understand pdfs are ripped to .tifs in the process and the tiff is what the 9800 (gmg rip) uses to print with behind the scenes. If I want to use the light process colors to simulate actual spot colors close, how can I acheive this given it is ripping to a tif? Is there a better way to get spot colors to render closer to the actual spot instead of a straight 4color build?
3) If I want Gracol to be my standard. Proofing on glossy stocks and printing on a coated stock is fine. What about simulating how it will look on an uncoated sheet as it would look on the press? I have seen swop coated and uncoated profiles but I do think I have seen the same for Gracol.
4) Lastly, I would like to make content only proofs off our Konica 550 to assemble and finish to the finished product and use the Epson to create Color approval prints. Good idea / Bad Idea? If I want to do this what is the easiest way to ensure that I don't have issues with text or transparencies looking totally different. Convert pdf to a tif and print that to the Konica? I want the least conversions and step involved but do issue that could relate to content. Again it is a content only proof I am looking for and I do realize I could run a backed up epson but, would be much simpler if I could just run it on the Konica on the actual stock.
Any feedback on all or some would be appreciated.
dale
dale
