Tech
Coloring items in black is the usual practice by most designers. Most don't take the extra step on setting their spot UV with an assign spot color. In some cases, coloring items in black is the easiest method for them depending on complexity (or poor file construction) of their design.
I like to know how many of you would absolutely kick this type of files back to designers and insist on proper spot UV setup just so you can get an easy separation? or would you take the extra mile and make the fix on your end?
Also correct me if I'm wrong, all spot uv gets separated and map to black anyway? If such spot UV layer is already setup as a separate layer...am I wrong to think printer just need to output that layer separately and rename it whatever they like?
