Is it possible that a 1mm PVC sheet will get compressed and thinner (0.1mm) after running several times through a screen printing machine? Anyone experianced on this, is it even possible?
The ink is a very regular UV ink that is commonly used. Its specifically recommended for PVC and similar plastic use.
All the prints where perfectly in scale and all, but the thickens of the sheets was thinner then expected. Since we did not measure before and after, we just where wondering if the sheet can get compressed after going like 10 times under high pressure through the printing process OR if the sheet was thinner to begin with.
And since we have printed all sheets we can not find it out, so I was wondering if its a common known effect or not.
If that effect would be known, then we could next time just start with a thicker material.
