We upgraded to 8 only because some our Quark customers upgraded to 8.
We like Quark 8 for one reason...native transparency support when making a PDF has FINALLY been added with the Quark 8.1 update...flattening is no longer required. In my humble opinion, this should have been done in Quark 7.0.
I heard that if you import a pdf w/transparency into Quark 8.1 that it can't export it back out w/transparency - only transparency created in Quark. Guess you have to crawl before you can walk.
Unfortunately, that is correct. Only Quark-generated transparent items can be exported natively. Any kind of placed content containing transparency will require flattening.
That Export Option is for transparency created in Quark. Below that option is one for "Transparent Objects In Imported PDF & Ai Files" that requires a "Flattening Resolution".
Flattening of the placed PDFs gets handled by JAWS on import, I don't think the flattening resolution for Export would make any difference to the quality. Quark specifically said NOT to re-place a native transparent PDF that it generated back into a quark layout but rather flatten it first.
I downloaded a trial version of Quark 8. Not really impressed. Personally, I don't like the GUI. And, it still has the same problems as always. You cannot open an earlier Quark file made from another computer without encountering possible font and reflow issues.
I miss Quark 3.3. Simple, direct and never crashed.
