I am interested in how other screen printers and their prepress depts handle incoming files, and how they measure/monitor film and print quality.
Even if you feel you could do better, I would still be interested in how you handle things, even if you think it's not quite correct.
I am trying to see how others do it, and how I can improve on how I do it too.
BRIEFLY ABOUT US
We are screen printers, printing Stationery Products and Point of Sale. Mostly PMS colours, but we do some CMYK work. We print at 65lpi.
I am in prepress. I check incoming files for obvious errors, fix them if needed, get approval from client then output the film positives.
I manually trap my files and use Cibercat Digiser5 for our films on an epson 9880. It's a basic rip to output film separations. This was setup to output films with tone for tone (eg: 30% tone on file is 30% tone on film etc) (I understand this needs to be changed, as i want to aim for ISO standards)
The file is saved as an .eps as Cibercat can have troubles with PDFs and leave things out!
We don't have a densitometer so print quality is just by eye, and this is how it's been done for years here.
I wouldn't be able to tell you (for eg) if our 50% halftone, when printed, was 30%, 50% or 70% on the sheet etc.
This is obviously a problem when printing CMYK, as you may only notice your cyan is too heavy when you are laying down your 2nd colour.
It's even a problem when printing 1 colour, as you want your tones to be correct, but it's more obvious in CMYK.
Obviously with colour bars, you would pick this up right away and adjust as necessary, even easier if we had a densitometer.
We use Marabu UV ink.
WHAT WE ARE AIMING TO DO
QUESTIONS FOR YOU!
SUGGESTIONS AND TIPS FOR ME!
There are many things I want to do (down the track), but as a starting point, I just want to know a few things from other screen printers out there.
I would love to hear of any other suggestions and tips you may have for us, or anything else you think you could share with me to improve our screen printing and film production.
Brett
BRIEFLY ABOUT US
- I want to aim for ISO 12647-2 Standards (or 12647-5 for screen print). Our CMYK inks are ISO 2846-4 compliant, so we should be able to get close to ISO specs. Anything at the moment will be better.
- I have ISO 12647-2 (and 12647-5) Standards sheet and Idealliance Guide to Print Production Version 12, as guides for specs to aim to.
- I have borrowed a densitometer and a transmission densitometer to measure the films.
- I am doing some initial print trials by printing a set of 1 colour black halftones, and measuring the results on film and the printed sheet.
- I can then see which halftone is printing at which value (Taking Dot gain into account).
- I can then adjust the linerisation curve when i output our films so i can then make sure our halftones print on the sheet as per ISO 12647-2.
- I am still in the process of doing this, also waiting for other valuable info before continuing.
QUESTIONS FOR YOU!
- Colour Management - How do you handle files with CMYK profiles. Do you just keep it the same profile, and preserve numbers, do you re-assign the profile, or do you just ignore what profile they have used and just output using the file's CMYK values?
- Have you measured your film's halftones, if not, how have you set up your rip/printer and how did you control what halftone came out on the film?
- Do you print and measure a colour bar for density, dot area etc. with a densitometer.
- If not, how are you judging that you are printing the correct colour and tone?
- Are you aiming at any print standards/ dot gain targets, or just a good looking print? How do you judge it?
- How do you trap files? Manual, Indesign trapping or ripping software.
- What rip are you using to make film positives?
- What brand of film are you using for your positives?
- Do you print at the best resolution on your printer (eg: 1440dpi) or does 720dpi do a good enough job.
Brett
