Quickmaster 46 -2 Help
Island print
Plate cylinder PU1 not aligning with the Plate feed table it opens and is ready to take the plate but about 2-3 inches away from alignment. Any help would be great. Thanks
Hi sir:
I recommend you, to see the operation for Pneumatic Cylinder Y6 in PU1 ,will work like the PU2, see if the mechanism is Good, or loose the pipes or, leak in the cylinder, or dirty in the swin lever, and lack of lube in any chain of movement of autoplate.
Hope this is problem using the auto plate, since you are mention clamp close manually and I you can not fit the plate in PU1, right?
Blessing3
[email protected]
Mobile+WhatsApp:+505 88611441
