What about the Canon?
Have you asked the following; how many machines each company has placed, for references, tours so you can ask operators for there honest opinion and how often they have to call service. Service is huge! It will make or break you. Have you tested your work on these devices? They always have those pretty little test files that come out looking so nice but real application is a totally different matter.
+1 that service is at least as important as the "badge"
I'm probably mistaken here, but isn't the KM C652 an office copier/printer? If you are comparing against a Xerox 550 and Ricoh light production kit, shouldn't you really be comparing the Bizhub Pro C5501 or even the newer C6000? Then you can spec a proper high cap feed tray with air separation, which will really help out feeding coated and difficult stocks.
Sorry if I've missed the point!
I think you need to consider issues like whether the machine is capable of reliably duplexing oversized gloss paper with a reasonable level of f-t-b registration accuracy. Personally, I'd ignore the voltage question as not really relevant.
