Ricoh 9200/9500 Magnification
Ricoh Lover
Hello, were currently experiencing magnification issues. We are continuously having to manually adjust the settings. This process is taking 15-20 minutes multiple times a day. Is there a better way to adjust these settings to where it can be fixed quickly?
I have found that Making sure to use the same paper brand/size on your stock helps keep this in check. I still have to adjust although not every time. I usually get it about right with in a couple sheets. I have seen some papers that can not be adjusted to correct size and its Thick cover stock or C1S stuff mostly in which case i will maybe lower or raise the GSM a bit. Also if nothing ever gets better you could also try and Delete the problem papers in catalog and remake them.
