About the die-cut lines, yes there are some software that can provide the structural design of the rigid boxes, and only need to input the sizes information to generate the final die-cut lines. If you want to know, I could share it with you, but their language is Chinese.
Small-quantity rigid packaging production usually requires:
1. semi-automatic die-cutting machine (automatic die-cutting machines are not suitable for small-batch rigid boxes production),
2. semi-automatic hot stamping machine,
3. corner pasting machine,
4. V-groove machine,
5. assembly line,
6. assembly machine,
5. other auxiliary machines.
But the most important thing is that compared with the folding card paper boxes, the rigid boxes require more labor (this is due to the various structures of the rigid boxes, so many processes cannot be completed by machines).
Suppose you want to expand your business scope and increase your rigid packaging business. In that case, it is recommended to cooperate with a more cost-effective rigid boxes factory to reduce costs, so that you can better focus on business expansion.
Xiamen USEE Packaging is a company specializing in the production of rigid packaging boxes. We can supply you with various customized rigid boxes, if you want to expand your rigid boxes business, we sincerely welcome you to cooperate with us.
